Author Topic: 16 valve clocks in a 88 gti 8 valve  (Read 2443 times)
Offline veedubmk2golf
« on: 13 February 2008, 18:50 »
pretty simple this I just want to know weather I can install 16 valve clocks into my 8 valve gti, the clocks I have now have two plugs and I know that the valvers are twin so will it be a case of plug in and there you go?
Offline richard s
Re: 16 valve clocks in a 88 gti 8 valve
« Reply #1 on: 13 February 2008, 20:24 »
i have a pb engined gti and think my clocks are from a 16v as they are 160 mph and 7000rpm so if yours is a pb engined model they should work
Offline takethefifth
« Reply #2 on: 14 February 2008, 11:43 »
The twin and single plug difference depends on the year. Can't remember which though! If the two cars are similar age, ie. both pre or both post 90, then it should work..... I give no guarantees though  :grin:  Have a search, this is covered is detail somewhere.
Offline leavingeasy
« Reply #3 on: 15 February 2008, 12:53 »
I have a set of 16v clocks from a 1988 car, 80,000 miles on them.
PM me if you want them.
coming to some armco near you soon.....
« Reply #4 on: 18 February 2008, 12:27 »
yeah as said just make sure it has same number of plugs as your old set.  speedo and rev counter will read properly, but the redline will be 1k too high!
Offline nealey
« Reply #5 on: 18 February 2008, 22:02 »
would it still work correctly if you just fitted the 160mph dash speedo into the 8v housing?
« Reply #6 on: 18 February 2008, 22:21 »
Yes, just make sure you have the right speedo drive cog in the gear box.  If you currently have 120 clocks then 160 should drop straight in, if you have 140 ones you will need a different drive.
« Reply #7 on: 19 February 2008, 08:24 »
Recently I found that the speedo gear has nothing to do with the speedo, its actually down to the gearbox you have fitted to your car, have a read of the speedo/ring & pinion gear section on brokes site:
http://www.brokevw.com/020ratios.html
« Reply #8 on: 19 February 2008, 13:04 »
Well blimey, I will hush my mouth!  :smiley:
« Reply #9 on: 19 February 2008, 13:13 »
I thouight the same as you a while ago!  broke is the gearbox genious that showed me the error of my ways  :grin:
