Author Topic: BOOST PRESSURE WITH REVO REMAP  (Read 3436 times)
Offline samy_1800_turbo
« on: 13 February 2008, 18:42 »
in second gear wen i put my foot down the boost gauge shows 15psi then drop down to about 5psi at the end of the rev range, it does it in every gear but second is the worst. mine alway used to drop a lil but not this much i fink i mite av a leak. does any1 elses do this. thanks
Offline richw911
Re: BOOST PRESSURE WITH REVO REMAP
« Reply #1 on: 13 February 2008, 19:03 »
In a word no!! Drops off a bit not that much tho mate  :undecided:
Offline mike4golf
  • 1.8t
« Reply #2 on: 13 February 2008, 19:09 »
as said mine drops but def not that much fella
« Reply #3 on: 13 February 2008, 19:24 »
ill tighten all my hose clips up n see if that makes a differance. n is it possible to pressure test the system and see if it holds its pressure wen engine is not runnin.
Offline richw911
« Reply #4 on: 13 February 2008, 19:27 »
Dont know - vag com or fault code reader should show up tho  :undecided:
« Reply #5 on: 13 February 2008, 19:30 »
what do your cars boost at if youv got remaps.
Offline richw911
« Reply #6 on: 13 February 2008, 19:32 »
17psi
« Reply #7 on: 13 February 2008, 21:30 »
ya mine used to boost dat now it barley reaches 15psi n drops straight down  :sad:
Offline MaXXeH
  • Golf MK5 GTI
« Reply #8 on: 13 February 2008, 22:19 »
you have the yellow spring in ur dv?  as green only does 5-15psi and then loses it all if u go over it.
« Reply #9 on: 14 February 2008, 19:13 »
im not sure i bought it second hand. n cum wid no other springs
