Author Topic: Heater  (Read 2091 times)
Offline ian00uk
Heater
« on: 13 February 2008, 16:49 »
My heater only works on number 4. Number 1,2,3 doesnt work at all.what could cause this
Offline AlanD
  • MK5 2.0T 16v
Re: Heater
« Reply #1 on: 13 February 2008, 17:18 »
Off the top of my head, faulty switch?
Offline richw911
Re: Heater
« Reply #2 on: 13 February 2008, 18:27 »
It sounds like you have a problem with the resistors that control the fan speed,as these are used on the three slower speeds.
Apparently the resistor assembly is at the bottom of the heater motor enclosure,and has four fairly thick wires going into it.
A friend of mine also had this on a focus
HTH.
Offline ian00uk
Re: Heater
« Reply #3 on: 13 February 2008, 18:37 »
is this a big job to fix?
Offline richw911
Re: Heater
« Reply #4 on: 13 February 2008, 18:56 »
Doesnt look too bad TBH have a look at this mate:
http://www.nime.co.uk/fancontrollerinstall.html
The part is £26.63 plus the vat from vagparts.
Type in speed resistor in the search box top right.
https://sslrelay.com/s74326199.oneandoneshop.co.uk/sess/utn;jsessionid=1547b33ac091e8a/shopdata/index.shopscript   :wink:
« Last Edit: 13 February 2008, 18:59 by richw911 »
