Author Topic: Quick lowering question  (Read 860 times)
Offline daniel-1986
« on: 12 February 2008, 12:34 »
i think my mate might have bought lowering spring set for his mk2 golf with a maximum of 120mm drop. will he incur any problem with 16" wheels
Offline Organisys
  • Old and Slow...
Re: Quick lowering question
« Reply #1 on: 12 February 2008, 12:51 »
Probably yes, depends on wheel offset, tyre size though.
Offline daniel-1986
« Reply #2 on: 12 February 2008, 13:01 »
i think its a 245/45/16 and they were off a vauxhall astra i think as his mate offered them to him
Offline Organisys
  • Old and Slow...
« Reply #3 on: 13 February 2008, 12:49 »
245!? I think he is going to have big problems.
« Reply #4 on: 13 February 2008, 12:57 »
not to mention vaux centre bore is too small, if they dont fit on easily whatever you do dont use the bolts to force the wheels on, you'll never get them off again!
Offline daniel-1986
« Reply #5 on: 13 February 2008, 16:20 »
the bore is bigger than the golfs its just a pain lining the bolt up
Offline Mew
« Reply #6 on: 13 February 2008, 16:56 »
They will most likely wobble, not good!
« Reply #7 on: 13 February 2008, 17:03 »
in that case they are missing the spiggot rings, measure up the size of the hole and get a set designed for a vw, centre bore of 57.1.  If you dont do this thew wheels wont centre and wobble all over the shop, dangerous as said!
