Author Topic: throttle body?  (Read 2660 times)
Offline GOLF_STU
  • THE_GIT
throttle body?
« on: 11 February 2008, 22:53 »
need a lil help the cars runnin like poo  :angry: the idle is lumpy it lurches when pullin away from standstill and back firing through the exhaust. i was thinkin the throttle body as on past fault codes it reads pressure loss between turbo and inlet  :huh: its an aum 2001 model by the way
any help would be greatfully appreciated  :cool:
V TEC KICKED IN Y'ALL!!!
Offline davy80
Re: throttle body?
« Reply #1 on: 12 February 2008, 01:51 »
if its missin it could be a coil-pack or try a treatment thriugh it and see if that works, or spray a load of carb cleaner into the carb, throttle body is the dear part try the small things first chum.
Offline ub7rm
Re: throttle body?
« Reply #2 on: 12 February 2008, 07:32 »
I had that code and it was a dirty TB, just needs cleaned.
2020 BMW 128ti
2017 Golf GTD Estate
Offline J5H VW
Re: throttle body?
« Reply #3 on: 12 February 2008, 09:10 »
I had a similar problem sometimes when pulling away, no backfire though.  Same engine, 2001 AUM.  I cleaned the throttle body out with carb cleaner, all works fine now.
2001 VW 1.8t Golf GTi 5 Door (AUM). Xenons, Heated Black Recaro Leather, Front Arm Rest, Stubby Alloy Bee-sting, Climatronic, Heated Washers, Headlamp Jets, Touareg Torch...and a fire extinguisher should it all go wrong! - NOW SOLD
2005 BMW 330cd M Sport Convertible - Sparlking Graphite, Full Electric and Heated Red Leathers, TV, Nav, Bluetooth, Active Xenons, Wind Diffuser
Offline richw911
Re: throttle body?
« Reply #4 on: 12 February 2008, 18:10 »
Offline GOLF_STU
  • THE_GIT
Re: throttle body?
« Reply #5 on: 12 February 2008, 23:04 »
cheers il give it a go  :smiley: it definatly isn't a missfire i think the butterfly vale in the tb isnt openin right  :undecided:
