Author Topic: Problem with power hood  (Read 1952 times)
Offline tezz1
« on: 11 February 2008, 19:41 »
Anybody else had one like this? Used the hood cover for the first time since buying my '96 Cabrio AG in December....now it won't shut or open on switch. According to the handbook, the power is disabled when the cover is in place. Tried all sorts, cleaning contacts etc but not a bleep from the hood motor!!
Any ideas please? :
Offline saul79
Re: Problem with power hood
« Reply #1 on: 11 February 2008, 21:58 »
does it not have a reset button
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline Pete Taylor
« Reply #2 on: 12 February 2008, 12:14 »
Don't hoods have a series of sensors in the boot to detect the movement of it? If a sensor has gone it could be telling the motor not to work
Offline tezz1
« Reply #3 on: 12 February 2008, 18:41 »
Can't see a reset button and no mention of one in the handbook supplement, any idea where this would be?
I think the cover has sensors on it because the electronics detect when it's on and don't allow raising of hood. It's always worked fine until I used the cover for the first time Sunday.....
Offline Pete Taylor
« Reply #4 on: 12 February 2008, 18:42 »
There is always a manual override for power hoods which allows you to open and close it manually for such an incident like this
Offline saul79
« Reply #5 on: 12 February 2008, 22:33 »
refere to the manaul for the above
Offline tezz1
« Reply #6 on: 14 February 2008, 10:51 »
Can't find a reset button anywhere, have closed the roof manually but no idea how to reactivate the electric motor. Will this be covered in the Haynes manual?
Offline Mikester
  • Civic Type R
« Reply #7 on: 14 February 2008, 23:10 »
I dont think so... NOt in mine anyways.
Offline tezz1
« Reply #8 on: 18 February 2008, 12:44 »
OK finally cracked it....connected the hood pump direct to the battery which re-booted the system...now works perfectly!   sigh of relief....
