Author Topic: mk 1 golf GTI  (Read 828 times)
Offline luckson317
mk 1 golf GTI
« on: 11 February 2008, 17:50 »
Hello, will it be alrite to run the 2ltr 8v engine with the 1.8 mk1 gti gearbox?
Re: mk 1 golf GTI
« Reply #1 on: 13 February 2008, 12:42 »
yep no problem at all, just make sure you match the clutch kit to the gearbox, not the engine and re-use your old flywheel.
If your car has a 200mm clutch though, I'd advise you upgrtade to a MK2 GTI 210mm clutch kit and flywheel.  You may be able to use the MK3 flywheel thoguh, I'm not 100% sure its the same as a MK1/2 one though...
