Author Topic: Revs At Idle...  (Read 2710 times)
Offline Ashmond
  • Money, b!tches And Boost
Revs At Idle...
« on: 11 February 2008, 15:54 »
What are the revs meant to be at idle and they are meant to stay there arent they? Because as of lunch time my revs fluctuate from 900rpm to just over a 1000rpm? Car is juddering slightly too, not loads but i can notice it, any suggestions?
Offline Rhyso
Re: Revs At Idle...
« Reply #1 on: 11 February 2008, 16:01 »
mines at 850 so not sure if its the same for your petrol lads; don't it rev higher initially if its cold too? so it could be up as high as 1100 - 1200rpm for a minute or two  :undecided:
Offline Ashmond
Re: Revs At Idle...
« Reply #2 on: 11 February 2008, 16:06 »
Yeah they do rev louder when cold but thats not what I mean it is just revving up and down at idle, hard to explain. Petrol head any ideas?
Offline rheady
Re: Revs At Idle...
« Reply #3 on: 11 February 2008, 16:14 »
When its cold mine revs up to about 1200 for about a minute or two then settles down to about 950.
1.8t BTW
Offline ub7rm
Re: Revs At Idle...
« Reply #4 on: 11 February 2008, 16:25 »
Could be dirty TB or iffy MAF / O2 sensor.  All these caused a blippy idle on my 1.8T (until they went proper tits up and it was a really rough idle).  Watch out for wildly fluctuating revs after slowing down for a roundabout junction too......
2020 BMW 128ti
2017 Golf GTD Estate
Offline AlanD
  • MK5 2.0T 16v
Re: Revs At Idle...
« Reply #5 on: 11 February 2008, 17:03 »
Mine does 1100 at cold and then 900 once its warm. If that helps . . .
Offline Ashmond
Re: Revs At Idle...
« Reply #6 on: 11 February 2008, 17:07 »
MAFS f**k ME OFF!!
(Sorry for that outburst)
Offline Ridg
  • TDI - Soot Happens!
Re: Revs At Idle...
« Reply #7 on: 11 February 2008, 21:43 »
i'd probably say its just to automatic choke causing the engine to run faster due to the cold.
Offline ub7rm
Re: Revs At Idle...
« Reply #8 on: 12 February 2008, 07:31 »
If its only happening when cold I agree its nothing to worry about.....
2020 BMW 128ti
Offline VapourTrails
Re: Revs At Idle...
« Reply #9 on: 12 February 2008, 18:17 »
i had something simular turned out to be one of the lambda sensor. plugged the comp in at my mates garage and it showed up so we tested it in a golf he had there and it ran like crap. changed it and all like running right now :D
