Author Topic: gear linkage!?  (Read 1048 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
gear linkage!?
« on: 10 February 2008, 23:35 »
I got my gearbox box back in today! with GREAT Difficulty i would like to add.  Anyway is there a special way to sort out the gear linkage alighnment?  because at the moment 1st is where reverse is and god only knows where 5th has dissapeard to!
Cheers   :cool:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline boneybradley
  • Back in a Mk3...
Re: gear linkage!?
« Reply #1 on: 10 February 2008, 23:55 »
use rubjonnys mk2 guide as they are similar to the mk3 020 box and the linkage is the same to set up http://www.golfgtiforum.co.uk/index.php?topic=33100.0
Offline Rmachines
Re: gear linkage!?
« Reply #2 on: 11 February 2008, 22:34 »
Cool! cheers,  it looks a bit tricky unless i got that tool,  are those tools available from auto factors or is it a specialst jobby?   Does the gear stick just need to be in dead centre while the box is set to neutral?
  • Back in a Mk3...
Re: gear linkage!?
« Reply #3 on: 11 February 2008, 22:59 »
some of the mk2 guys sell the tool/spacer thing...or give the bay a try
Offline saul79
Re: gear linkage!?
« Reply #4 on: 12 February 2008, 17:38 »
£6 on ebay for the tool :smiley:
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
