Author Topic: wheel bolt  (Read 1661 times)
Offline 1688bran
wheel bolt
« on: 10 February 2008, 12:32 »
  just got some 19's wheels is it ok to use the original wheel bolt or i need longer ones ...
Offline GTi-Matt
Re: wheel bolt
« Reply #1 on: 10 February 2008, 16:26 »
id say so but wouldnt know 4 definet without seeing the wheels mate, u got any pics?
I must warn you I'm about as decisive as a 5 yr old in a sweet shop!!  :grin:
Offline richw911
Re: wheel bolt
« Reply #2 on: 10 February 2008, 17:30 »
My 18" wheels came with slightly different bolts depends on the wheels as already said  :smiley:
Offline GTi-Matt
Re: wheel bolt
« Reply #3 on: 10 February 2008, 17:55 »
you've gotta get the right fixing kit if there aftermarket wheels, if there genuine vw then that should b ok, but as i said before a pic would let me know 4 certain
« Last Edit: 10 February 2008, 17:58 by kke1 »
Offline 1688bran
Re: wheel bolt
« Reply #4 on: 10 February 2008, 18:48 »
  got them fitted earlier .. it seems good ,got roughyl about 9 turns out of it . will post some pic tommorrow ....
Offline GTi-Matt
Re: wheel bolt
« Reply #5 on: 10 February 2008, 18:50 »
are they after market wheels then? id probs get some longer bolts mate 9 turns is not alot.
Offline 1688bran
Re: wheel bolt
« Reply #6 on: 10 February 2008, 19:03 »
http://www.thewheelconnection.com/php/showwheel.php?name=Chaos&brand=Absolute&bolt=5x114.3&wheelsize=18x8&tireid=all
these the wheels i got .... but in 19's ! do u know where i can get longer wheel bolt from ???
Offline GTi-Matt
Re: wheel bolt
« Reply #7 on: 10 February 2008, 19:15 »
the hub dosent look to be that big, did they fit straight on or did u need rings or spacers? without a load of hassle of getting new bolts drive about 30 miles is what recommended and go back to the tyre garage and get them to re-torque them at 120nm then u can be sure they will be ok
Offline 1688bran
Re: wheel bolt
« Reply #8 on: 10 February 2008, 19:24 »
they fit straight on didnt need rings or spacers ...... i already drove more than 30 miles it seems fine ...... might get longer wheel bolts to make sure tho
