Author Topic: cortesy light ??  (Read 2071 times)
Offline leeroy20vt
  • h reg mk2 gti
cortesy light ??
« on: 09 February 2008, 22:11 »
drivers  side cortesy light  doesnt work i taken it out put in pass side works fine checked there is volts at drivers side and there is!!!!!!!!
 but still dont work any ideas
Offline richw911
Re: cortesy light ??
« Reply #1 on: 09 February 2008, 22:21 »
Yeah not good news sounds like your lock module is fu****  :sad: cost about £70 from vw.  Do you get probs with the locking on that side?
Offline leeroy20vt
  • h reg mk2 gti
« Reply #2 on: 09 February 2008, 23:27 »
no not at all no lockin probs like i said i tested the wires and theres life in them so dont understand weird a
Offline richw911
« Reply #3 on: 10 February 2008, 02:09 »
Yeah ive got the same prob mate. Ive got power there aswell  :shocked: Maybe the switch inside the lock module in the door is faulty, or maybe the soldering has come loose on the circuit board?
Offline leeroy20vt
  • h reg mk2 gti
« Reply #4 on: 10 February 2008, 08:40 »
i still dont under stand how its not workin if there is power rite up to the plug that plugs into the back of the light  baflin a  :huh:
Offline GTi-Matt
« Reply #5 on: 10 February 2008, 09:37 »
it is the switch mate m passenger side light did that and manged to get a switch 4 7 quid and had the electrician at work to do it 4 me :cool: :cool:
I must warn you I'm about as decisive as a 5 yr old in a sweet shop!!  :grin:
Offline leeroy20vt
  • h reg mk2 gti
« Reply #6 on: 10 February 2008, 09:39 »
ok cool i think ill just leave it well alone then more hassle than wat its worth me think lol :laugh:
Offline Rhyso
« Reply #7 on: 10 February 2008, 10:00 »
get a bulb!! bulb blew in mine; got one yesterday and two minutes later all is bright  :grin: :grin:
Offline leeroy20vt
  • h reg mk2 gti
« Reply #8 on: 10 February 2008, 10:04 »
rhyso the bulb ok i swapped it for pass side all worked fine the power to the plug and there power at either end of the fitting were the bulb sits but still no go weird m8 well weird
Offline Rhyso
« Reply #9 on: 10 February 2008, 10:08 »
have you tried tightning the bulb?? i think they work on a 1/4 turn and if not seated correctly won't light up; worth a try before spunking cash on a new module
and i'd still try a new bulb; even if there is power up to the plug then it surely can only be the bulb  :undecided: couple of quid from a dealer
