Author Topic: clocks  (Read 735 times)
Offline 2pac
clocks
« on: 09 February 2008, 21:53 »
hi folks
maybe i will buy second hand clocks with mfa.
i don't hAVE THE mfa stalk, so how i do i make the digital time to display after i connect it?
if you disconnect the battery, does it turn automatically to the time?
Re: clocks
« Reply #1 on: 11 February 2008, 13:23 »
without the stalk the mfa will function as a clock, to set the time you use the 2 buttons on the front of the dash either side of the clock :)
Offline 2pac
Re: clocks
« Reply #2 on: 11 February 2008, 14:32 »
even if the clocks were dismantled from the doner car when another function was displayed?
Re: clocks
« Reply #3 on: 11 February 2008, 14:33 »
yep they'll reset, no 'memory' in the dash :)
only issue is sometime they go a bit nuts when they loose power, but just pull the fuse for 30 seconds and try again!
Offline 2pac
Re: clocks
« Reply #4 on: 11 February 2008, 18:20 »
thx. :smiley:
