Author Topic: number - under the engine  (Read 1656 times)
Offline JC
  • Back in the North.
« on: 09 February 2008, 21:25 »
on my multiple trips under the golf today cleaning up oil I found a indentifcation mark with 9a then 5 numbers
what does this mean please
its at the gearbox end of the engine underneath
Stoopid question no doubt but i is learning slowly of the VW ways  :grin:
Offline nealey
Re: number - under the engine
« Reply #1 on: 10 February 2008, 00:00 »
Well that would mean that at some point somebody has removed the Kr lump and fitted it with a 2.0 9a
Offline JC
« Reply #2 on: 10 February 2008, 10:04 »
 oops - look like i fcuked up - its on the  bell housing of gearbox not the engine  :laugh:
engine number matches log book its a kr one -
so - what does that plate mean about my gearbox ??? as i got one of those weird 8 pin plugs where the normal 2 pin reverse gear should be  :cry:
« Last Edit: 10 February 2008, 10:53 by chuff »
Offline hobbiniho
« Reply #3 on: 10 February 2008, 14:36 »
gearbox from a 9a i should imagine
Offline jammac
« Reply #4 on: 10 February 2008, 15:56 »
ive got a 9a number on my 8v gearbox.............so that blows that thoery out the window  :drool:
ITS A TRAP!
Offline JC
« Reply #5 on: 10 February 2008, 16:07 »
 :grin: whens the MOT due  :shocked:
Offline jammac
« Reply #6 on: 10 February 2008, 16:24 »
27th it runs out.so prob nxt weekend...im scared  :evil:
ITS A TRAP!
« Reply #7 on: 11 February 2008, 13:08 »
it just means the gearbox code is 9a, which is correct for an early valver :)
the difference is it has a combined upshift light/reverse switch, whereas the 2y box just has a reverse light switch :)
Offline JC
« Reply #8 on: 11 February 2008, 14:34 »
cheers johnny
going to change the box for the spare one I got in the garage once I have cleaned and painted it up as its got the correct 2 pin switch for the reverse switch.
But top info
« Reply #9 on: 11 February 2008, 14:37 »
no problem :)
just fyi you can wire in the upshift switch reverse light pins to a later car, broke has a handy how2:
http://www.brokevw.com/
