Author Topic: MOT question headlights  (Read 704 times)
Offline iddlesgti
  • one way ................. dub way
« on: 09 February 2008, 20:35 »
last week i lost the use of my headlights (i had sight lights and main beam but no dipped) as a quick fix i cut the sidelight feed and connected it to my dipped feed. will this pass an MOT or do i need side lights as a completly seperate connection any ideas as to what might cause this. and will this pass the dreaded test
cheers lads
Offline Jay
  • balding fat cvnt
Re: MOT question headlights
« Reply #1 on: 09 February 2008, 21:47 »
Depends where you go  :laugh:
Otherwise try this, Section 1 is lighting  :smiley:
http://www.motuk.co.uk/manual/contents.htm
Offline catflea
« Reply #2 on: 22 February 2008, 21:07 »
Your dip and sidelights do need to be a seperate feed.
The only time I've had that happen (it was a type 2,  not a golf)  it was the headlight relay.    So worth and investigate
