Author Topic: advice/help needed  (Read 4651 times)
Offline beni-iow
advice/help needed
« on: 09 February 2008, 16:30 »
hi all just bought a gti 8v and ive just noticed after a few days of having it that the abs light does not come on.im guessing that the bulb has gone or been taken out :sad:
the breaks seem ok they work fine ect.if its not got a bulb in will be checking later and the abs light comes on will the chances be its a sensor fault?if so is it an expensive part/parts to get.any advice will be much appreciated thank you.
Offline beni-iow
Re: advice/help needed
« Reply #1 on: 09 February 2008, 17:27 »
just checked and the bulb for the abs warning light has blown so im gunna try and get 1 tomorrow and hope that it will all be ok
Offline Mikester
  • Civic Type R
« Reply #2 on: 09 February 2008, 17:30 »
1. When you start the car does it go on an off. If not. Bulb is broken or taken out SO......
2. Find a straight section of road thats quiet, drive at 40mph and slam the brakes on, if you skid and the pedal doesnt vibrate, someone has taken the bulb out or broken it, as the abs is not working.
(this is commen, as they get faults all the time, so peopel cheat to sell it)
Probably only a broken sensor to fix IF its broken, about £17 for a sensor from GSF online.
 :smiley: Hope that helps, any queiries just ask  :wink:
Offline Pete Taylor
« Reply #3 on: 09 February 2008, 17:45 »
Does your handbrake warning light stay on? Infact, does you handbrake warning light even come on when the handbrake is applied?
Offline Mikester
  • Civic Type R
« Reply #4 on: 09 February 2008, 17:53 »
This would mean a pump or multiple fault with your abs.
Offline beni-iow
« Reply #5 on: 09 February 2008, 18:43 »
handbreak light comes on and off as normal.i took the bit out that has the bulbs in for abs and airbag and the abs bulb is blown so fingers crossed thats the problem..i hope..
Offline Mikester
  • Civic Type R
« Reply #6 on: 09 February 2008, 18:48 »
If not you can test it now as i said, but just breaking hard and seeing if it kicks in.
If not, use the airbag bulb to test the abs light?
Offline boneybradley
  • Back in a Mk3...
« Reply #7 on: 09 February 2008, 18:53 »
and remember the abs fitted to pre 96 cars is prehistoric and some skidding is normal! mine slides when wet/icy and the abs works but not like more modern systems...
oh mines not faulty as its being fully tested and given the all clear?
Offline Mikester
  • Civic Type R
« Reply #8 on: 09 February 2008, 18:59 »
My light is on, good thing i got HOT A$$ brakes, so it really dont matter for now  :laugh: Its been broken since i joined this forum!
Offline beni-iow
« Reply #9 on: 10 February 2008, 12:09 »
right havnt been able to go down any roads and safly brack hard so i went and got a bulb,went to change it but i cant get the old bulb out of the holder tried abs bulb and air bag one and both stuck in there.so im proberly gunna take it to the auto sparkys across from my work and get them to do it. :angry:
