Author Topic: k-jet 8v fuel pump not priming - but there is a twist!  (Read 4160 times)
Offline TRANTER
  • golf mkII gti 8v
Re: k-jet 8v fuel pump not priming - but there is a twist!
« Reply #10 on: 10 February 2008, 18:54 »
im in the same boat as you mate everything you have said at the top is whats mine is doing but earlier it started and after about a minute it cuts off, then again starts then off now nothing wont even start but turns over , then you here the buzz from the pump i dont get it and ive gota get to the body shop at 7 in morn for its spray job :sick:
can anyone please help
i.e
battery
plugs
anything please
Offline cняis
« Reply #11 on: 10 February 2008, 20:24 »
Is it too obvious to suggest getting a new fuel relay??
Probably not to be honest, it just threw me a little how the relay does click and the pump does prime, but only after you try to start the engine rather than before!
The pump priming after and not before is throwing me a bit on my project. It will only run with the key held in position 3, as soon as its released the motor cuts out. although a new ignition switch has been suggested.
Offline TRANTER
  • golf mkII gti 8v
« Reply #12 on: 10 February 2008, 20:26 »
yes thats howits looking but i drove mine around 200 meters fine then it started to play up, but befroe i did drive it it was sat idling fine so i dnt get it
Offline md1980
« Reply #13 on: 16 February 2008, 22:05 »
hello guys i dont know if any of what im about to say u will understand
i have just got my self an 86 golf gti  this has the k jet engine i got the car as a none runner and from the sound of what alot of you are saying is what i have been doing over the last few nights
i tested both pumps for power but i could'nt under stand why there was'nt anything there till i turned the key but by the by i the test the in tank pump i have a thing called a power probe which use battery power to work any way that tested fine so then i tested the main pump but there did'nt seem to be any thing there so i went out today and got another pump try and tested befor i fitted but after fitting i cracked the feed pipe at the front of the car to make sure the fuel was getting there but it was'nt in the end i had to prime the main pump with the in tank one i did this with the power probe on the main pumps plug as they both use the same feed after doing this there was fuel at the front of the car as for not priming all the time frrom what i can gather it will only prime when the ignition is on if the pressure in the fuel line is low
hope this helps
Offline md1980
« Reply #14 on: 16 February 2008, 22:08 »
aswell if the main pum is shafted u can make a digifant pum fit that is what i did
« Reply #15 on: 18 February 2008, 12:44 »
dont fit a digifant pump to a k-jet car,m it cant supply enough fuel, plus needs some horrible bodges to the fuel lines to make it fit.
Offline Ben Lessani
« Reply #16 on: 19 February 2008, 10:00 »
My K-Jet doesn't prime before starting either, its done that for the past 18 months. It will only need to prime if the fuel pressure is low. On a failed start, you hear the pump prime.
In terms of the pump, just because its drawing a +12v and whirring doesn't mean its working! My old fuel pump used to make all the right noises, but it didn't actually do anything. Best way to find out is to remove the fuel line off the fuel dist block on top of the air filter and see if theres any pressure, or remove the pump housing altogether and test the lift pump on its own, and check the pressure pump on its own.
« Last Edit: 19 February 2008, 10:18 by blessani »
« Reply #17 on: 19 February 2008, 10:12 »
the fuel pump should always prime regardless, theres nothing anywhere that 'knows' what the fuel pressure is ;)
Offline Ben Lessani
« Reply #18 on: 19 February 2008, 10:19 »
I was just throwing in my 2p - mine has never primed on the turn of the ign, maybe my accumulator knows the fuel pressure and mysteriously informs the fuel pump it can have a day off.
« Reply #19 on: 19 February 2008, 10:28 »
or maybe your fuel system aint working properly :grin:
