Author Topic: MOMO steering wheel vs. airbag warning light!  (Read 2784 times)
Offline eightyeightmph
« on: 08 February 2008, 22:13 »
Following on from this http://www.pocketrocket.ca/momo_wheel.html
I've fitted my MOMO steering wheel, looks superb & really like how it feels when driving.
However,
Obviously now the air bag is disconnected the warning light (above the abs light) is permanently on when the ignition is on.
My question is, aside from removing the bulb, is there a way round this? :huh:
2016 GOLF GTD
Offline raylee25
Re: MOMO steering wheel vs. airbag warning light!
« Reply #1 on: 08 February 2008, 22:17 »
smash the airbag bulb
Offline BobbyT
« Reply #2 on: 08 February 2008, 22:24 »
you can buy a resistor from vw, not sure what the part number is mind, will try to find out, fools the car into thinking the bag is in place  :wink:
« Reply #3 on: 08 February 2008, 22:40 »
2016 GOLF GTD
« Reply #4 on: 08 February 2008, 22:41 »
ORLY? That's interesting, thanks for that, let me know!  :smiley:
2016 GOLF GTD
Offline BobbyT
« Reply #5 on: 08 February 2008, 23:53 »
i belive the part number is '1H0 972 478 A'  from vw and is £7 - hope this helps  :wink:
« Reply #6 on: 09 February 2008, 07:51 »
Ah, brill. Does it just plug into the socket where the airbag is removed from?
Thanks for that!
2016 GOLF GTD
Offline saul79
« Reply #7 on: 09 February 2008, 09:09 »
yes it does . :smiley:
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
« Reply #8 on: 21 February 2008, 09:18 »
Well picked up the resistor from the stealer & plugged it in where I unplugged the airbag & no change?!
Light still flashes on ignition & then stays on when running?
2016 GOLF GTD
Offline BobbyT
« Reply #9 on: 21 February 2008, 09:59 »
if you have run the car without it, it might be worth disconecting your battery and leaving it a bit to reset everything, then make sure the resistor is pluged in when you re-connect it, that way the car should think all is well. worth a try  :undecided:
