Author Topic: cabrio cutting out  (Read 3546 times)
Offline peter doc
cabrio cutting out
« on: 07 February 2008, 23:08 »
hi ther just new to this site. i have an 89 cabrio 1.8 gti and just started getting this problem the car starts fine and runs fine until i open the throttle right up then it stars to die and stuter but if i let go of the throttle it will idle no problem i can drive the car on just a little throttle it will rev all the way with no hesitation but as soon as i open the throttle up it stars to die again i haqve changed the plugs,leads ,fuel filter,checked the gauze in the tank for any rust nothing found i have used the search on the site to see if icould find any ansers there but couldn'd find anything on it any advice would be much apprecaiated thanks
Offline gibby
Re: cabrio cutting out
« Reply #1 on: 08 February 2008, 08:29 »
My next step there would be to try a new rotor arm and a new dizzy cap. Should be cheap enough from GSF. Also, I know you've checked the gauze, but just to make sure, check your filler neck is not rusty as they have a nasty habit of getting rust in the fuel system and it causes no end of problems.
......now officially dubless.
« Reply #2 on: 08 February 2008, 10:51 »
do the spark plugs while you're there, get tripple probe ones if given a choice but i thin std they are tripples anyway.
Try http://www.vwspares.co.uk, normally cheaper than gsf...
Offline peter doc
« Reply #3 on: 08 February 2008, 21:31 »
cheers for that i'll have look at the filler neck tomorrow and change the dizzy and the rotor arm and let you know thanks
Offline peter doc
« Reply #4 on: 09 February 2008, 17:59 »
well nothing has changed still the same after fitting the dizzy and rotor arm checked the  filler neck bit of surface rust nout major if anyone has an idea about wot it might be your help would be much appreciated
Offline gibby
« Reply #5 on: 09 February 2008, 18:14 »
It's a long shot as this is usually hot starting problems, but take the fuel relay out (I think its the big one, top left on the fuse box) and check the connections on it and sandpaper them if necessary. Other than that I don't know what it might be, but have you also checked all the wiring and connections in the engine bay, maybe it could be a dodgy earth or a loose wire somewhere, it has been known before.
Offline [han]
  • Graphic Designer for Haribo
« Reply #6 on: 09 February 2008, 22:10 »
a good service always is a good place to start i think, then just keep replacing.. trial and error!?
i found my haynes has good troubleshooting tips for probs like this when i've had them :)
Don't give up!
Offline peter doc
« Reply #7 on: 10 February 2008, 23:08 »
i took the dizzy and rotor back off again and noticed that the part you slide the rotor arm onto has a bit of side to side movement is this normal i gather its supposed to spin round but not wiggle side to side??
Offline peter doc
« Reply #8 on: 12 February 2008, 23:29 »
don't know wot i done played about with the dizzy and it's going mint cheers for the advice much appreciated :smiley: :smiley:
Offline gibby
« Reply #9 on: 12 February 2008, 23:33 »
Glad we could help. :afro:
