Author Topic: replacing door lock mechanism  (Read 1229 times)
Offline golfmk31993
« on: 07 February 2008, 13:21 »
hi,
the lock mechanism in my drivers door is not working , basically the little latch inside the door drops and wen i shut the door it just bounces back open, i have to push it up with my finger and then quickly shut the door before it drops again.
i want to replace this mechanism inside the door anyone know how to do this???
my car is a 1993 vw golf mk3 with no electric windows or central locking,
thanks
Offline saul79
Re: replacing door lock mechanism
« Reply #1 on: 07 February 2008, 17:32 »
door handle off 2 screws-  door pin off -screws off and and doorcard is clipped on.
seal behind the door card is smegged on -heat with an hairdryer to heat glue makes it easy to take off
then undo the torx screws holding the latch on and remove it
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline golfmk31993
« Reply #2 on: 07 February 2008, 18:21 »
ok thanks alot for your help, i just wanted to check that there no special tools needed or problems wich arrise when doing this,
thanks
