Author Topic: god i hate induction kits  (Read 1102 times)
Offline iddlesgti
  • one way ................. dub way
« on: 06 February 2008, 22:43 »
hi everyone i bought a 1991 gti last week and i was full of water and very sluggish however to today fitted a standard airbox and she is like a whole new car responsive and very quick
but now i can hear all the other problems
1. wheel bearing
2. driveshaft
but i have found out why the pas dont work the belt is slack how hard is this to tighten
cheers fellow GTIers
Offline richardhammond
Re: god i hate induction kits
« Reply #1 on: 06 February 2008, 22:46 »
Sounds like you need a pee mate LOL :laugh: :laugh: :laugh: :laugh:
Offline Jay
  • balding fat cvnt
« Reply #2 on: 06 February 2008, 22:58 »
Wheel bearing is easy enough, just take it to a garage to get it pressed in the drum (assuming its a rear drum brake? probably not so i'm ready to get shot down  :grin: ) will only cost £10 - £ 15 for half hours labour.
Drive shaft, not a fcking scooby on how to sort those  :laugh:
PAS, no idea my car is manual all the way  :grin: But I'm thinking maybe a new belt if your's is slack (stretched?)
The search feature is great  :smiley:   (Unless you are my mother and don't know how to use google  :shocked: )
Offline barry sprout
« Reply #3 on: 07 February 2008, 00:11 »
You really need to be doing this sort of stuff at home, unless as Jayton says, it's a very easy job (then why not do it yourself?)
These cars are uneconomical to keep going by paying for other people's labour!
Wheel bearings - knock them out and clean, regrease, replace using old bearing and or appropriate size socket to drift them in. Reassemble, use new split pins. Check play after a few days - tighten spangly nut if needed.
Drive shafts - wots wrong?
Power steering - there is an adjuster bolt to tension belt located on the bracket next to the pump pulley, don't forget to loosen the lock nut on the inside of the bracket beforehand.
Have fun  :laugh:
Offline iddlesgti
« Reply #4 on: 07 February 2008, 19:04 »
cheers lads
i want to do all the work my self so ill have a go
Offline iddlesgti
shuddering
« Reply #5 on: 07 February 2008, 19:06 »
hi everyone just a quick note if your having problems with shuddering i took my induction kit off and fitted a standard air box and the shuddering has gone!!!
must of been fuel starvation
hope this helps someone
« Reply #6 on: 08 February 2008, 11:06 »
there are tons of bolts n stuff for the PAS adjuster, its a right pain in the arse!  There are some nicely hidden ones you get to from above too, just keep loosening stuffs till it moves  :grin:
