Author Topic: Removing the door card eleccy window replacement.  (Read 3115 times)
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
« on: 06 February 2008, 22:09 »
Braught a replacement window mech of ebay and wanna try and change this myself, ideas on removing the door card?
Offline saul79
Re: Removing the door card eleccy window replacement.
« Reply #1 on: 06 February 2008, 22:12 »
door handle off 2 screws-  door pin off -screws off and and doorcard is clipped on.
seal behind the door card is smegged on -heat with an hairdryer to heat glue makes it easy to take off
if the window doesnt go down it will take longer to take off the 2 x 10mm nuts that hold the glass in
other than that its pretty straight forward unplug the motor
 undo the 10mm bolts that hold the reg on and slide it out
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline DazVR6
« Reply #2 on: 06 February 2008, 22:18 »
So just prise the door handle off..? and once you remove the screws the door card just pulls off..?
Offline MowatGTI
« Reply #3 on: 06 February 2008, 22:19 »
You can't go wrong mate.
Im a total novice and have done it a couple of times.  I also just bought a mech from the bay.
As long as you remember where everything goes its a doddle.
I found some bits a bit hard to get off, only because they are plastic and didn't want to break them, but in the end they shifted no problem.
How much did you get the mech for?
Offline MowatGTI
« Reply #4 on: 06 February 2008, 22:19 »
Don't touch the handle.  It stays in.
Offline DazVR6
« Reply #5 on: 06 February 2008, 22:22 »
£56 including postage.....so wheres the screws, at the bottom of the door card..?
Offline MowatGTI
« Reply #6 on: 06 February 2008, 22:27 »
Got my one for £50.  Yours brand new aye?
Can't remeber off the top of my head, but as soon as the door card comes off, its obvious.
The Haynes manual has a walk through of it too.
Offline Paul86S2
« Reply #7 on: 06 February 2008, 22:36 »
try http://www.icbm.org/erkson/personal/mycars/door_panel_removal.htm
from the maintenance info at the top of the mk 3 section
also look in there for window mechanism replacement under diy guides
cheers
Paul
Offline DazVR6
« Reply #8 on: 10 February 2008, 20:07 »
Ok well tried to do this today but got a little stuck, got the door card off and removed the nuts that hold the regulater inplace but couldn't get the brackets that hold the glass out, its impossible as there is no room inside that part of the door and i didn't want to brake the glass.
What am i doing wrong..?
Offline saul79
« Reply #9 on: 10 February 2008, 20:11 »
the window motor is dead then - use a 10mm rachet spanner .is the mech- snapped or is the motor dead
