Author Topic: Changing suspension myself...how hard..?  (Read 2550 times)
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
« on: 06 February 2008, 22:06 »
As some of you know i got some Jamex suspension to swap over on my car, now if i was to have the right tools i.e spring clamps, would this be hard to do myself?
Offline saul79
Re: Changing suspension myself...how hard..?
« Reply #1 on: 06 February 2008, 22:09 »
no its easy take about 1 1/2hour if nothin is corroded  :laugh:  make sure you get the camber and tracking checked after its done :smiley:
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline DazVR6
« Reply #2 on: 06 February 2008, 22:20 »
Anyone know what tools i might actually need ? i know ill deffo need spring clamps, any idea on price ?
Offline Mikester
  • Civic Type R
« Reply #3 on: 06 February 2008, 23:46 »
Theres a thread on how to do this somewhere, try using the search function.  :cool:
Offline DazVR6
« Reply #4 on: 07 February 2008, 00:42 »
No, can't be arsed.
Offline Mikester
  • Civic Type R
« Reply #5 on: 07 February 2008, 19:30 »
No, can't be arsed.
Then you cant be arsed to change your suspension :P
Offline saul79
« Reply #6 on: 07 February 2008, 20:10 »
no special tools needed fella. just the coil spring compressors. socket set and some spanners does the job
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #7 on: 07 February 2008, 23:23 »
If its anything like every car i have ever done suspession on (allot) you will need an air gun to zip the top nuts off else the strut just spins!  You might be lucky.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline DazVR6
« Reply #8 on: 07 February 2008, 23:54 »
Heard you need a "special tool" to get it loose, anyone know what its called? suspension was only changed about a year and a half ago so shouldn't be any ceased/difficult nuts. :shocked:
Offline oggy
« Reply #9 on: 08 February 2008, 09:48 »
1 1/2 hours! No chance - even with a ramp. Take you time and reckon on best part of 10 hours if you use a jack and do all 4.  Bet your bottom dollar you come against a stiff nut etc. Spring compressors cost me a tenner from motor factors. Replace all top mounts and bottom bushes. The bottom bushes usually come with the strut. Personally I just cleaned up the springs and replaced the struts with Bose gas shocks - £27 each.
Flats on the strut thread at the top end meant I did not require a special tool for the rear, but the front is a different matter. Again motor factor should supply. Hayes manual shows how to make one yourself - not difficult.
Agreed that camber and tracking to be checked afterwards, but drive it a while first to let it bed in.
