Poll
Running/starting problem
mk3 starting
2 (66.7%)
mk3 stalling
1 (33.3%)
Total Members Voted: 3
Author Topic: can any one help mk3 not starting!  (Read 826 times)
Offline Abz585
« on: 05 February 2008, 18:37 »
 Please help all? Mk 3 Starting
« on: Today at 18:02 » Quote Modify
Can any one help Mk3 gti 8v one 73,000 N-reg. The car came home from work this morning no problem started a couple of hours later it ran for about half a mile coughed and stopped.
checked over car got fuel in pistons well plugs are wet and can smell petrol. Got a good spark at the plugs when cranked over. changed fuel filter today. its had dizzy cap plug leads plugs rotar arm all less than 2000 mls ago
Checked relay 3 in fuse box it clicks on ignition not a guarentee of working i know but at least it trys.
I'm well stuck any suggestions please? cheers Dave
Been at it again today, put a new relay in still no result! Also checked timing, the car is engine code AEK and it has the AGG simos management & fuel system.  Any help would be appriciated :cry:
« Last Edit: 06 February 2008, 21:18 by Abz585 »
Offline Mr Blue
Re: can any one help mk3 not starting!
« Reply #1 on: 07 February 2008, 16:03 »
Im not a mk3 nerd but check the Crank Sensor. Quite a common problem.
The sensor is behind the front engine mount so you will ned to remove that to gain access.
« Reply #2 on: 08 February 2008, 10:30 »
ecu coolant temp sensor would be my first port of call
