Author Topic: Is it broken?  (Read 749 times)
Offline Randy Spacemonkey
  • you can live in your car,you can't race your house
Is it broken?
« on: 05 February 2008, 15:45 »
The end of my injector came off. Is it ment to? Will it be ok if I just push it back on? 89' 16v
Thanks Rob
Offline Conker
Re: Is it broken?
« Reply #1 on: 05 February 2008, 16:04 »
Mine didn't have that end piece on them, so I would guess its fine without it. Remember to make sure your injector seal ring isn't perished while your at it as their only a few pence from GSF.
Leon R
Re: Is it broken?
« Reply #2 on: 05 February 2008, 19:07 »
Not really meant to on original VW injectors, I've seen some Bosch ones without this and they seem to work fine as Conker said.
I bought Bosch ones from GSF for £30 each and they had the ends, I think the end part controls the spray pattern so without it, you might have some rough running. No harm in trying it tho.
Hard to say whether putting it back on will be ok or not, I'm sure this part can fall into the inlet manifold and probably jump around the valve stem which is not good.
Re: Is it broken?
« Reply #3 on: 06 February 2008, 12:06 »
Thanks think i'll try without, if its crap I'll buy new ones. Dont realy want to risk it falling off.
Re: Is it broken?
« Reply #4 on: 08 February 2008, 10:57 »
yeah my thoughts exactly, if it falls off it'll end up in the cylinder!  If tyou want newuns get a set of merc brass ones off ebay, about £50 a set  :cool:
