Author Topic: can someone explain to me?  (Read 2363 times)
Offline Chris 'N' Jen
  • MK4 2.0 GTi 8v in black (the best colour)
« on: 05 February 2008, 14:57 »
Ever since we've had the car we have had cold starting isues. I had plans to take the throttle body appart again this weekend.
Had it remaped yesterday and guess what - no more starting troubles. Can someone please put their 2 peneth in as to why this might be as im pretty baffled.  :undecided:
cheers y'all
Offline Ashmond
  • Money, b!tches And Boost
Re: can someone explain to me?
« Reply #1 on: 05 February 2008, 14:59 »
Maybe something to do with petrol at start up or maybe ECU just needed to be resetted (both guesses!)
« Reply #2 on: 05 February 2008, 15:13 »
was thinking something along the lines of the ecu needing resetting.
Forgot to mention that i had a green pannel filter put in too. i was thinking maybe air starvation was the problem but the standard filter was only a month old.
Offline Ridg
  • TDI - Soot Happens!
« Reply #3 on: 05 February 2008, 15:14 »
i'd go with the ECU too
or maybe a few cobwebs got blown out after the remap.
Offline J5H VW
« Reply #4 on: 05 February 2008, 15:14 »
Not sure what this could be, but would go with the ECU needed to be reset.  I never had any issues with mine! touch wood!
2001 VW 1.8t Golf GTi 5 Door (AUM). Xenons, Heated Black Recaro Leather, Front Arm Rest, Stubby Alloy Bee-sting, Climatronic, Heated Washers, Headlamp Jets, Touareg Torch...and a fire extinguisher should it all go wrong! - NOW SOLD
2005 BMW 330cd M Sport Convertible - Sparlking Graphite, Full Electric and Heated Red Leathers, TV, Nav, Bluetooth, Active Xenons, Wind Diffuser
Offline ub7rm
« Reply #5 on: 05 February 2008, 15:23 »
Yay - you managed to get that sorted then!
Quite an impressive way to clear a fault too!
2020 BMW 128ti
2017 Golf GTD Estate
Offline Ashmond
« Reply #6 on: 05 February 2008, 15:26 »
I doubt it would be the standard panel filter tbh
« Reply #7 on: 05 February 2008, 15:32 »
Im not counting me chickens yet, but yer, good way to cure a problem.
Ash - i wouldnt have thought it would have been that esp as it was new.
Cheers gents, just had me a bit baffled as to why a remap would cure it. Ill be back if it goes back to its old tricks.
Offline AlanD
  • MK5 2.0T 16v
« Reply #8 on: 05 February 2008, 15:47 »
What BHP you getting out the 2.0 lump now then?
Offline Rhyso
« Reply #9 on: 05 February 2008, 15:48 »
i had an intermittent problem where if i didn't travel very far in the first few minutes then i'd get a slight fluctuation when idling but since having the remap thats cured it.
I think VW tended to release software updates which got loaded at your services during the warranty period.  Chances are this may not have happened so the remap with its new updated code has cured the problem.
