Author Topic: Mk 3 8v water leak  (Read 1781 times)
Offline madmanmavis
Mk 3 8v water leak
« on: 04 February 2008, 17:35 »
Hi guys just posted this in garage but thought some of you might not look in there very much.
Ive got a water leak in my 8v ive attached a picture below its coming from where the cooling system connects to the head.
What is this part called? I need to sort this leak fairly quickly its a right pain in the arse!
Is there a gasket here that might have failed?
Cheers Matt
Offline saul79
Re: Mk 3 8v water leak
« Reply #1 on: 04 February 2008, 18:37 »
front coolant housing :smiley: most of them crack around the copper ring or the plastic deteriates through age around where the gasket sits  :smiley:
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline madmanmavis
« Reply #2 on: 04 February 2008, 19:01 »
Cheers!
whats the best way to drain the coolant system on a Mk3 ie which hose to pull?
Offline saul79
« Reply #3 on: 04 February 2008, 19:02 »
bottom hose and if you remove the thermostat more water will come out :smiley:
Offline Mikester
  • Civic Type R
« Reply #4 on: 04 February 2008, 19:13 »
If you have the standard sqweeze clip on the hose, replace it with a jubilee hex head one, be so much easier for next time around.
Offline madmanmavis
« Reply #5 on: 04 February 2008, 21:16 »
Next time how often do these bloody things break  :wink:
Offline Mikester
  • Civic Type R
« Reply #6 on: 04 February 2008, 21:23 »
When you change the coolant everyyear for winter......  :nerd:
Offline saul79
« Reply #7 on: 04 February 2008, 21:51 »
dont need to change coolant every year ,bloody hell would cost a fortune . pink stuff is every ten years  :laugh: blue/geen is every 3 years  :smiley:
Offline kr1s77
« Reply #8 on: 20 February 2008, 01:38 »
madmanmavis did you change the housing, changed my coolant about two ago, now noticed its leaking from that same spot. so need to change that to now. looks like i'll loosing some coolant. just put in new G12+ aswell  :cry:
ASV 1.9 TDI 110
Offline Stu G
« Reply #9 on: 20 February 2008, 08:17 »
its about 11 quid for that housing and seal from main dealer :)
