Author Topic: Wiper stalk stuck  (Read 1297 times)
Offline percymon
Wiper stalk stuck
« on: 04 February 2008, 16:36 »
2 days from thne MOT and the wiper stalk won't mive upwards - i can get it to the flick wipw contacts, but not to speed 1 or speed 2 - feels like its mechanically obstructed.  The intermittent and the wash/wipe  and rear wiper functions are fine.
Before anyone asks i didn;t see a puff of smoke from the area - they worked fine this mornign on the commute, but not now.
I'm fearing its a strip the steering column job, anyone think it might be relay related ???
Offline saul79
Re: Wiper stalk stuck
« Reply #1 on: 04 February 2008, 18:40 »
if theres nothing obstructing it from moving ,its the switch, never seen /heard of one failing though :smiley:
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline percymon
« Reply #2 on: 04 February 2008, 21:15 »
Cheers - i figured it had to be the lever, so i called at local ECP o way hoem, picked up a new one for £20.
After 20 minutes studying the diagrams on the workshop CD, I went at it - took 30 minutes top to..
disconnect battery
remove airbag (held on by 2 5mm hex headed bolts from the rear)
disconnect airbag (prised off yellow connector on back of unit with small flat screwdriver)
Removed steering wheel (24mm locking nut) - being carfeul not to disturb any airbag calibration ring on the rear.
Undid the 3 slotted screws holding in the stalks - positioned at 10, 1 and 7 o'clock
disconnected the four electric connections to the two column stalks
slid off the two stalks
slid on the new wiper stalk, then the old indicator stalk
refitted reverse of removal.
Fired up ignition - Airbag light check went as normal  :smug: :smug:
Offline Mikester
  • Civic Type R
« Reply #3 on: 04 February 2008, 21:27 »
disconnect battery
Nice work, always worried about playing with the airbag!!
Offline saul79
« Reply #4 on: 04 February 2008, 21:49 »
i just pull em off at work surpose to disconnect battery but no need ,not had one go off yet . blew a few up though :laugh:
