Golf mk2
Banging rear coilover (with pic)
Topic: Banging rear coilover (with pic) (Read 1411 times)
gerlewis
GTI forum regular
04 February 2008, 14:24 »
Hi guys, my rear passenger side coilover is banging on bumps, I have taken this shot from inside the boot and you can see the big rubber bump stop isn't sitting in the cup properly.
anyone know how to rectify this?!
Ger
gerlewis
GTI forum regular
Re: Banging rear coilover (with pic)
04 February 2008, 14:25 »
do I need to adjust something under the wheel arch to eliminiate the play?
Ger
Horney
10k hero
Racing, Trackdays, Starwars.
04 February 2008, 14:31 »
From memory there is another rubber of similar design under the arch and it may have perished and fallen off. Jack the car up and have a look under the arches on both sides to compare. If all looks OK take the parcel shelf support off and do up the nut on top of the strut until the rubber is back in place. that should sort you out.
Nick
gerlewis
GTI forum regular
04 February 2008, 14:39 »
Thanks mate, the reason I am reluctant to do up the top nut is cos the other shock has the smae amount of thread sticking out the top, so I presume they are balanced.
I will look under it this weekend.
Ger
paultownsend
04 February 2008, 14:41 »
there is a small cir clip on the top of the pistoton, just below the threads. happened me
gerlewis
GTI forum regular
04 February 2008, 20:04 »
whats the solution paul? do the shocks need removing and all that jazz?
You are talking about coil overs not standard setup right?
paultownsend
Reply #6 on:
04 February 2008, 21:37 »
yes they will need removing. there is a groove in the piston, and in there they should be a cir clip.they only cost 30p or so from vw
daniel-1986
Here all the time
Reply #7 on:
05 February 2008, 09:58 »
this is where the cir clip goes as i had the same problem
heres the part u need with the arrow pointing at it
www.midsdubclub.com
gerlewis
GTI forum regular
Reply #8 on:
05 February 2008, 10:38 »
just to re-iterate, I have aftermarket adjustable coil overs.
So would this be the same problem/part number?
Thanks for all the advice guys.
gerlewis
GTI forum regular
Reply #9 on:
05 February 2008, 10:41 »
PS Daniel: in the picture of yours, it looks like you could just stick the circlip back on there without removing the shock. Am i right?
Ger
Golf mk2
