Author Topic: Losing water, think its the pump  (Read 1563 times)
Re: Losing water, think its the pump
« Reply #10 on: 08 February 2008, 11:44 »
the early ones were metal ;)
Offline Uruk Hai
« Reply #11 on: 08 February 2008, 11:47 »
Are they still available and if so will they fit a later digi ?
« Reply #12 on: 08 February 2008, 12:29 »
the std one is discontinued, but you can still get a diesel type with a threaded hole in it
068 121 145 K - 27.79
037 121 687 - seal - 1.60 (think this is the right one, dealer should confirm)
To plug the hole you can fit an mfa oil temp sensor or a 16v coolant temp sensor :)
Offline Uruk Hai
« Reply #13 on: 08 February 2008, 12:42 »
Thanks for that, I'll see how this one goes and if it isnt any better I might get the ones you've listed. I'm just supprised that even with a genuine part fitted it still appears to be leaking  :undecided:
« Last Edit: 08 February 2008, 12:59 by Uruk Hai »
Offline Lap
« Reply #14 on: 08 February 2008, 23:29 »
I had the same problem. I replaced the flange on the side of the head but it started leaking soon after. I  took it off again and placed it on a piece of glass. You could see that it was warped. This was probably because I had done up the bolts too tight. I think you only need 10Nm torque - not much at all.
I bought another one, cleaned up the surface thoroughly with some wet and dry, then I applied some hylomar blue gasket sealant to the head before fitting the new flange. I also used a torque wrench so I wouldn't over tighten the bolts. It never leaked again. Well, not from there anyway!  :smiley:
Offline Uruk Hai
« Reply #15 on: 10 February 2008, 19:05 »
Seems to be O.K at the moment but I'll see what its like as the week goes on and if it still steams from the same place I might end up using some sort of sealer or liquid gasket, fingers crossed it wont need it   :undecided:
