Author Topic: 2.1 16v turbo conversion  (Read 2372 times)
Re: 2.1 16v turbo conversion
« Reply #10 on: 08 February 2008, 10:23 »
you'll need to do something to drop the compression, boost on a std 8v engine will blow it up quickly!  2 G60 metal gaskets should do it, either that or new pistons.  Depends on the boost levels you plan to run! remember the std 8v lump isnt designed for boost really, not like the G60 bottom end which has oil squirters for the pistons n stuff like that.
Offline stefgolf
« Reply #11 on: 08 February 2008, 13:53 »
so if i get some low compression pistons and 2 metal head gaskets it will be ok? or will the g60 pistons fit? thanks
« Reply #12 on: 08 February 2008, 13:57 »
you use one or the other, not both ;)
g60 pistons would fit yes, but you might as well just get a G60 block tbh, much less hassle.  New pistons need the block honing, then you still have the lack of oil squirters which might casue you greif later on down the line.  A G60 head would be good to have too they have sodium filled valves.  You at least need the G60 cam or sports G60 cam, as the std GTI one wont be right for boost.  Its a little known fact the G60 cam isnt as agressive as the GTI one, too agressive cam means you loose boost out the zaust!
Offline stefgolf
« Reply #13 on: 08 February 2008, 14:06 »
ok thanks for the reply will i need to change wiring loom for a g60 engine?
« Reply #14 on: 08 February 2008, 14:14 »
yep, then std loom is in no way suitable for boost :)
Offline stefgolf
« Reply #15 on: 08 February 2008, 16:45 »
Thats what i didnt want to have to do, hense why i was goin to turbo the engine i already have in.
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #16 on: 12 February 2008, 17:06 »
sounds like a propa nightmare to do all this..1.8 20v seems the easiest option
Offline dabill
« Reply #17 on: 13 February 2008, 14:44 »
agree'd^ except i aint got a turbo in my new one hahah!
noble tuned - and still not fast enough!
