Author Topic: Idle problems, help plse!!!!!  (Read 925 times)
Offline elthespaniard
  • 1989 Mk 2 Golf Gti 16v
« on: 03 February 2008, 20:29 »
Hello guys,
slight problem, nothing to serious, i hope lol!!!
My Idle switch keeps running loose. The revs go from being around 900rpm, to 1300rpm. Thats idling quite high, too high, its buggering the fuel consumption, so i keep turning the idle switch down, bringing the idle back down to 900rpm and for a few days its ok, then the revs are back up!!!
If i turn the idle switch all the way down till it wont rotate antmore, ill drive the car for a bit, and as i slow down the engine will cut out, so obviously i have to rotate the switch up a bit, and then the car drives fine but im back to the original problem.
Does anyone have the same problem or can any1 gimme a hand with what to do????
Cheers peeps!!!!
Any help will be much appreciated
Offline monzablue16v
Re: Idle problems, help plse!!!!!
« Reply #1 on: 03 February 2008, 20:44 »
Is it a 16v? if so it could be the temp sender that controls the ISV or the ISV needs a clean :)
Offline Conker
« Reply #2 on: 03 February 2008, 20:50 »
Do you mean that you set the idle to the right amount, then over a short period of time it starts rising?
If so... I would check the rubber o-ring on the idle screw. If its perished, the screw might not be secure anymore.
« Reply #3 on: 04 February 2008, 00:28 »
Its a 16v, and yup, ill set it and over a period of time it rises, ill give the motor a check tmra, and ill keep ya posted,
cheers lads, help is much appreciated
Offline Mrpug
« Reply #4 on: 04 February 2008, 21:35 »
The temp sender :huh:?, I'm having some of the same problem, thanks for the suggestion
« Reply #5 on: 05 February 2008, 20:23 »
Yeah I was a bit like that as well but I swapped them around and hey ho the dash sender reads low and the car doesn't rev randomly anymore :)
It's one of those things you don't think of but when I did it made sense. The ecu and ISV are told the engine is cold so it adjusts to that but it is warm so it goes random!
