Author Topic: Loud bang on cold startup  (Read 2875 times)
Offline Alps
« on: 30 March 2004, 08:23 »
anyone know what this could be, its a loud bang coming from engine side on cold startup only, gonna get done by the firearms unit if it keeps doing it.
pumping fuel before starting seems to stop it? any ideas
Alps
Mk1 Rivage - 1992 Green
E55 AMG 2004
C36 AMG 1997- SOLD
MK4 1.6 SE - 1998
MK1 Rivage - 1991 Blue SOLD
Offline Gambit
Re:Loud bang on cold startup
« Reply #1 on: 30 March 2004, 09:47 »
is it a constant bang or just a one off bang on startup?
Offline richandhazel
« Reply #2 on: 30 March 2004, 13:59 »
Sounds like your ignition timing is quite a way out causing a back-fire.
Failing that and perhaps more serious, maybe you have a burnt out valve..........out with the compression tester.
« Last Edit: 30 March 2004, 14:00 by richandhazel »
Offline Alps
« Reply #3 on: 30 March 2004, 18:03 »
just a one off bang, other than that, the car runs fine!!
cant be the valves as it wouldnt hit 110 nice and smoothly and stay there would it?
Alps
E55 AMG 2004
C36 AMG 1997- SOLD
MK4 1.6 SE - 1998
Offline Gambit
« Reply #4 on: 31 March 2004, 09:22 »
it'll be an engine mount
turbo
« Reply #5 on: 02 April 2004, 03:12 »
extremely bad case of piston slap! ???
Offline Alps
« Reply #6 on: 02 April 2004, 18:41 »
cant be the engine mount as its like someone firing a gun! piston slap... maybe!?! what can i try to stop this, other half`s car, she has had it for 14 years and said its been happenin for the last 7!! car seems to run fine after initial startup bang, could it be sommin wrong with the dizzy cap or sommin?
Alps
E55 AMG 2004
C36 AMG 1997- SOLD
MK4 1.6 SE - 1998
« Reply #7 on: 02 April 2004, 21:46 »
From the sound of it I might not have been too far out^^^^^, check your ignition timing.
Offline modulater
« Reply #8 on: 02 April 2004, 23:26 »
As rich says it sounds like its not firing at first and when it does your back firing.
do you get a lovely petrol smell after the Bang?
