Author Topic: gearbox noisey in neutral!  (Read 3563 times)
turbo
« on: 30 March 2004, 01:25 »
my recon box has started to rattle in neutral it goes when i press the clutch pedal! my mate had a recon box in his, his is newer than mine....... but its strange that both boxes have started to rattle >:(
i take it that its the imput shaft bearing which are rattling!
is there any oil which will quieten this down!
ive changed the oil in it a few times!
Offline Gambit
Re:gearbox noisey in neutral!
« Reply #1 on: 30 March 2004, 09:46 »
you mean the thrust bearing?
i take it, it doesnt rattle when the car is stationary and you put the clutch down?
my thrust bearing has been whining ever since the day i bought it 2 years ago, just have never got round to changing it
changing the oils might quieten it down, try some Redline MTF in there
Offline davidhawkins_78
  • Valver Bad Boy
« Reply #2 on: 30 March 2004, 09:46 »
Could be the clutch release bearing ???
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Offline Gambit
« Reply #3 on: 30 March 2004, 09:49 »
same thing ;)
golfvr6
« Reply #4 on: 30 March 2004, 10:43 »
Could be the clutch release bearing or the gearbox input shaft bearing(which is different).
Offline richandhazel
« Reply #5 on: 30 March 2004, 12:30 »
Might well only be the clutch release bearing which can be replaced without removing the gearbox.
Offline bishthefish
« Reply #6 on: 30 March 2004, 23:34 »
Is it possible to remove bearing with box in situ ??
bishthefish@btinternet.com  VARIOUS NEW AND USED MK3 BITS USUALLY AVAILBLE
Offline modulater
« Reply #7 on: 31 March 2004, 00:32 »
Its not likely to be the release bearing as that would do it more when you push your foot on the clutch as your pushing the bearing against the release plate and also it would show up in every gear.
If it only does it in neutral I would say it is an input shaft bearing.
Push your foot on the clutch, does it still make the noise with gearbox disengaged?
« Last Edit: 31 March 2004, 01:33 by modulater »
turbo
« Reply #8 on: 31 March 2004, 01:03 »
i tried some wynns gearbox stop leak as there is oil under the box!!!!
anyway this stuff is like thick oil and is ment to do the same as the maxlife oil revitalise seals etc...........
and it also said it queitens noise and it did seem queiter!
Offline mk1
« Reply #9 on: 31 March 2004, 22:53 »
No oil in the box ?
Steve.
