Author Topic: Spring thing hanging down under car? pic added!  (Read 3363 times)
Offline terri8le1
« on: 02 February 2008, 19:17 »
Was walking back to my car today and noticed something hanging down, sort of level with where your feet would be sitting in the driver seat but underneath the car, it was on a hinge and looked sort of like a spring at the end of it, i pushed it back up and it sort of hooked on something, didnt seem solid though.
Any ideas what it is and where it should be?
Cheers in advance!
« Last Edit: 03 February 2008, 19:59 by terri8le1 »
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Spring thing hanging down under car?
« Reply #1 on: 02 February 2008, 22:45 »
I cant imagen what this might be!
Was it near the rear axle?  Could it have been the rear brake balence compensator spring?
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline terri8le1
« Reply #2 on: 03 February 2008, 00:41 »
No mate, it was at the front, roughly level with where the driver seat is, but underneath, i'll get a picture of it and put it up here.
Offline Mikester
  • Civic Type R
« Reply #3 on: 03 February 2008, 16:31 »
 :grin: :grin: :grin: :grin:
 :laugh: :laugh: :laugh: :laugh:
And your not worried about this? Still driving it?
Offline terri8le1
« Reply #4 on: 03 February 2008, 19:03 »
Sorry chaps, it was at the rear, near the axel, here's a pic
Offline saul79
Re: Spring thing hanging down under car? pic added!
« Reply #5 on: 03 February 2008, 20:11 »
thats off your brake compensator on the back, has a short 13mm bolt/nut on it to hold spring  on
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline terri8le1
« Reply #6 on: 03 February 2008, 21:20 »
Cheers, so what do i have to do with it matey? Whats its purpose?
Offline saul79
« Reply #7 on: 03 February 2008, 21:22 »
bolt it back on.its for when the car is loaded in the back it will let the brakes brake more on the back due to the extra weight  :smiley:
Offline herbster
« Reply #8 on: 03 February 2008, 21:23 »
it compensates the load in the back with the braking efficiency, the more the suspension is loaded the more pressure the rear brakes apply, as the set up is predominately front about 60-70% rear 30-40%, it attaches to a miniture cylinder above where it is with the said bolt, pretty important during the winter really, once you put your head under there you'll see the little sod!!!
FAB is my life and the CABRIO's the wifes!!!!
Offline terri8le1
« Reply #9 on: 03 February 2008, 22:27 »
Ah right, cheers fella's, will have a look at it first thing and get it back where it should be!
Thanks again. :cool:
2hours 45 mins left on ebay by the way :wink:
