Author Topic: Power to rail behind the head Please help  (Read 673 times)
Offline smithysmoo
« on: 02 February 2008, 14:02 »
Trying to sort my high idle issue out and got the multimeter to check that all the leads had power. Everything did except the rail behind the head below the throttle body. This is the one thats connected to the head. Should this be getting power when the ignition is turned. The car wasn't started as I have the ISV off cleaning it for the second time.
Please tell me
Offline Mr Blue
Re: Power to rail behind the head Please help
« Reply #1 on: 02 February 2008, 17:07 »
That sounds like the injector rail. :rolleyes:
Guessing it will only show power with the engine running. Doubt the engine will even run with it unplugged unless you tap into the wires.
I dont think that this is causing your your high idle.
« Last Edit: 02 February 2008, 17:10 by Mr Blue »
Offline smithysmoo
« Reply #2 on: 02 February 2008, 17:18 »
Cheers matey pulled the lead of with the engine running and it cut out so guessing thats working ok..... Bloody high idle is a nightmare.
Offline Mr Blue
« Reply #3 on: 02 February 2008, 17:23 »
I had this high idle problem.
It was the throttle switch (top one). The wires to it were broken as predicted by 'rubjonny'
