Author Topic: Help with knackered alternator bolt  (Read 2001 times)
Offline Alps
« on: 29 March 2004, 22:28 »
guys/gals, i vetried taking off the alternator on my mk1 and i think the thread on the allen key bolt near the cam belt is knackered as the bolt is tight as ****, whats the best way of getting this out?
cheers
Alps
Mk1 Rivage - 1992 Green
E55 AMG 2004
C36 AMG 1997- SOLD
MK4 1.6 SE - 1998
MK1 Rivage - 1991 Blue SOLD
Offline mk1
Re:Help with knackered alternator bolt
« Reply #1 on: 29 March 2004, 22:42 »
Hi Alps, If this is the lower alternator bolt I would take off the cam belt cover, remove the top alternator adjusting bracket  and try to get a good (not worn) 8mm? allen key and push the alternator towards the engine as you try to undo the bolt. Hope this helps.
Steve.
Offline Dizzie
  • Make friends with your fast
« Reply #2 on: 29 March 2004, 23:45 »
I feel your pain alps. I had the same thing recently. took a while but we got it off in the end and nipped to the scapper for another one.
Mk4 Golf 150PD
Offline Alps
« Reply #3 on: 30 March 2004, 08:21 »
cheers guys, already have the spare bolt will need to spend a bit of time doing this is think! may pop to halfords and get a 8mm allen key socket to make life easier!
i`ll let you all know how i get on!
Alps
E55 AMG 2004
C36 AMG 1997- SOLD
MK4 1.6 SE - 1998
VeeDubGTI16v
« Reply #4 on: 30 March 2004, 14:19 »
just slide a bit of piping/tubing over the allen key to make the lever longer, thus easier to turn.
Offline Alps
« Reply #5 on: 30 March 2004, 17:59 »
done that, bent the normal L shaped Allen key!
Alps
E55 AMG 2004
C36 AMG 1997- SOLD
MK4 1.6 SE - 1998
