Author Topic: URGENT: mk2 88 will not find 1 st and second  (Read 830 times)
Offline brems
« on: 01 February 2008, 19:57 »
my car was running fine, pulled up went to leave and it wudnt engage first or second, only 3rd and fourth.
i had a mess with the gear linkage, i could then get first and second but no 3rd or fourth?
would it be the bushes inthe gear linkage next to the engine, what are the alignments etc
really need to sort this i can get it on a ramp tnite
cheers
Offline bomp
Re: URGENT: mk2 88 will not find 1 st and second
« Reply #1 on: 02 February 2008, 09:37 »
You might have a hairline crack on the ends of the gear linkages, GSF sell them cheap enough.
The gear stick ball housing may also have worn down a bit.
Check Rubjonnys How To. http://www.golfgtiforum.co.uk/index.php?topic=33100.0
The relay shaft bush may also have worn out worn enough to effect gear selection. mk2mark sells a modified one which slips over the white plastic centre of the original one. http://www.iol.ie/~locoblade/bushes.html
Life is like a skid mark on a toilet bowl.  Sooner or later someone\\\'s going to pi$$ you off.
Offline Mrpug
« Reply #2 on: 04 February 2008, 21:15 »
I replaced the bushings in the linkage as I was having the same problem. The bushings had worn to all but nothing. I'd check the bushings since they help keep thing alligned.Have fun it's a rather simple job and one can use a casset tape in place of the expensive tool to get the things in the right places when adjusting the shifter.
Offline blackbeautymk2
« Reply #3 on: 07 February 2008, 19:06 »
Same thing happened to mine, had to order that plastic bit as it had cracked, the double ended ball jouint platic bit, just used a coathanger as a temporary fix!!!  :grin:
