Author Topic: Missfire!!  (Read 1380 times)
Offline ian00uk
Missfire!!
« on: 31 January 2008, 23:04 »
had this problem for few months now. when accelerate past bout 2500 revs the car missfires and pops out of exhaust real bad.things ive done is
new coil packs from vw
new spark plugs for vw dealer
new cat as old 1 had hole in it so thought this could have contributed to it
cleaned throttle body and reset
the car now struggles when idling and pulling off and going at low speeds.
also when i drive it a bit and then stop the fan comes on for about 5 seconds then goes off.
plugged into vagcom and it comes up with
cylinder 1,2,3,4 missfire and random missfire
any ideas?
Offline BobbyT
Re: Missfire!!
« Reply #1 on: 31 January 2008, 23:10 »
what do vw think buddy?  :undecided:
Offline ian00uk
Re: Missfire!!
« Reply #2 on: 31 January 2008, 23:12 »
dont know havent been to them, they will charge loads to look at it so thought id post on here see if any1 had ne ideas.taking it to few garages tomoz see wat they suggest
Offline topher
  • Administrator
  • fully functioning
Re: Missfire!!
« Reply #3 on: 31 January 2008, 23:18 »
Usually my first thought with things like this is MAF, but the vagcom result doesn't really back that up. How many miles has your car done and has the timing belt been changed? May have jumped a tooth..
Offline ian00uk
Re: Missfire!!
« Reply #4 on: 31 January 2008, 23:22 »
its done 73000 miles and had an engine rebuild on 67000 miles where it had the timing belt changed and other bits.how often should timing belt been changed?is there a way to check it? i replaced the maf bout 4 months ago
Offline topher
  • Administrator
  • fully functioning
Re: Missfire!!
« Reply #5 on: 31 January 2008, 23:27 »
It should have been changed when they did the rebuild.. if its messing up after only 6000 miles i would've thought the first port of call would be the people that rebuilt your engine?
Offline ian00uk
Re: Missfire!!
« Reply #6 on: 31 January 2008, 23:29 »
yeh but its been fine since rebuild until last couple of months.trying to narrow it down what it could be.
Offline topher
  • Administrator
  • fully functioning
Re: Missfire!!
« Reply #7 on: 31 January 2008, 23:31 »
any local backstreet garage should be able to check your timing, which might atleast eliminate my jumped tooth theory!
Offline ian00uk
Re: Missfire!!
« Reply #8 on: 31 January 2008, 23:35 »
ok mate will speak to em tomoz.thanks for ure help
