Author Topic: Steamy Windows  (Read 1127 times)
Offline Strev
Steamy Windows
« on: 31 January 2008, 09:20 »
Help please. Obviously there is a leak. Drivers side foot well is a bit damp. Took off door panel and repaired plastic skin at the week-end. It had come away but the bottom of the door panel still felt damp this morning! The drain holes look clear - am i missing something? Ice on the inside of the windscreen is not good!
Cheers.
Offline dabill
Re: Steamy Windows
« Reply #1 on: 31 January 2008, 10:42 »
actual door seal, the one that attatches to the body of the car?
get down to a scrappers and get one, fit it, hope thats it.
do a search on this section, there is a guide somewhere with every possibility pretty much of place that can leak on a mk2...
noble tuned - and still not fast enough!
Offline Strev
Re: Steamy Windows
« Reply #2 on: 31 January 2008, 10:46 »
Thanks! Think I can get a door seal from German and Swedish.
Offline dabill
Re: Steamy Windows
« Reply #3 on: 31 January 2008, 11:32 »
dont whatever you do go to the dealers, got me nearly 90£ for a set of 2!
ask around or find someone breaking a car, or like i say, scrappers.
Offline Steve_B
Re: Steamy Windows
« Reply #4 on: 31 January 2008, 11:39 »
I had a problem with water in the drivers side footwell and it turned out to be the drain hole above the wheel arch that was blocked. It's under the scuttle tray and the ECU as you open the bonnet. Worth checking out as it's free to fix.
Also, matey-matey have a decent checklist for finding leaks.
Offline dabill
Re: Steamy Windows
« Reply #5 on: 31 January 2008, 11:45 »
oh yeah, along with that, the black strip that runs down the side of the windscreen, there is a channel in the middle of that, i ran the jetwasher through that to clear it, that might be worth doing too... not sure if it will make a difference but if the person who owned it last like the the one that owned mine, didnt have a jetwasher, you'll be suprised at the amoutn of what can only be described as sh*t, that comes out of it.
Offline russ-vdub
  • Once a Dub, Always a Dub
Re: Steamy Windows
« Reply #6 on: 31 January 2008, 14:20 »
get a new water deflector from vw, its £25 but they redesigned the old crappy filmsy one and it works wonders.. i had major water leak through the heater fan cos my deflector was knackered.
Offline dabill
Re: Steamy Windows
« Reply #7 on: 31 January 2008, 14:22 »
if his is the 90 spec though it will prbs have the new deflector on it surely?>
Offline Strev
Re: Steamy Windows
« Reply #8 on: 31 January 2008, 17:22 »
Is a 90 spec - but the deflector does have a few splits in it.
Could it be the strip the sits between the window and the door - ie bridges the gap.
Thanks.
Offline russ-vdub
Re: Steamy Windows
« Reply #9 on: 02 February 2008, 15:12 »
yeh possibly, i need a new set of them,water gettin through killed my door speaker
