Author Topic: Car OverHeating only in a city.  (Read 4031 times)
Offline GTI16vGaz
  • New car will be displayed soon.
« on: 29 March 2004, 16:45 »
Hello again...
I have a quick question regarding the water system.
If i am driving through sheffield(city) and my car's running at normal tem(middle) and i start thrashing it a little it seems to not cool down but the fan is working! so aventually it will over heat unless i can get on a long straight.
If i drive steady through a town then car gets hot but the fan kicks in at the correct temp and cool's it down and its fine, it won't overheat.
Has any1 any idea's on this,
i've thought of 1 "don't thrash it through a city"  ;D but i'd like it resolved.
I think the water and antifrezze mixture is wrong it has more antifrezze than water could this be the culprit?  ???
Anyway any idea'a would be great cos its the only prob i have at moment!
Thanks,  ;)
Gaz
Offline richandhazel
Re:Car OverHeating only in a city.
« Reply #1 on: 29 March 2004, 16:50 »
Thermostat might not be opening fully.
Sig pic looks good ;)
« Last Edit: 29 March 2004, 16:51 by richandhazel »
Offline Gambit
« Reply #2 on: 29 March 2004, 16:52 »
so how far does it go above the 1/2 way marker? and what is the oil temp also
Offline GTI16vGaz
« Reply #3 on: 29 March 2004, 16:52 »
Yeah i'm happy with it, just ordered a big bumper kit from awsomegti needs spraying and fitting!!  ;D ;D
The thermostat is new, fitted about 8 weeks ago ish...
« Reply #4 on: 29 March 2004, 16:53 »
Is that when the problem started? I've had problems with new thermostats in the past.
Offline GTI16vGaz
« Reply #5 on: 29 March 2004, 16:56 »
Hi Gambit,
It sits in the middle all the time unless stuck in traffic then the needle moves on a little just before hitting the second marker the fan will kick in and cool the car down. but if thrashing it though a town then stopping etc.... the needle will just go right over to the right hand side unless i stop and turn the car off. The oil temp is between 98 - 103.
Offline GTI16vGaz
« Reply #6 on: 29 March 2004, 16:58 »
No it had a faulty system when i bought it last year in november so i replaced the thermo and it ended up being the fan so i replaced the thermo anyway as they are cheep.
Offline GTI16vGaz
« Reply #7 on: 29 March 2004, 17:00 »
Right i'm going home i'll check any response's tomorrow.
cheers lads. ;)
« Reply #8 on: 29 March 2004, 17:01 »
Hmmmm new fan..........I'm sure it shouldn't be possible but, just a thought, it isn't operating in the wrong direction is it? Pulling the hot air off the engine and through the radiator would cause said undesireable effect :-\
Offline tinman
« Reply #9 on: 29 March 2004, 23:12 »
Check the water pump and make sure all the spines are still on it.
Tin
