Author Topic: Golf v8 Setting MFA Clocks  (Read 2512 times)
Offline Spunky_XR4i_GTi
« on: 30 January 2008, 18:15 »
Hi just bought myself my first GTI, I don't have a hand book, and don't know how to set the MFA clock to display the time. I jabbed and held in the little pins but nothing happened...do you do it with the ignition on, off etc?
Secondly my rear wiper doesn't work what switch should do it?
Thanks muchly
Spunky  :cool:
Currently Driving
Ford Sierra XR4i 3.2V6 [A444 TGP] [Member XROC]
Volkswagen Golf GTI 1.8 8v [D242 HLJ]
Ford Sierra P100 1.8TD [H816 DBW]
Nissan Primera 2.0i SE [N]
Offline gavL
Re: Golf v8 Setting MFA Clocks
« Reply #1 on: 30 January 2008, 18:35 »
I'm glad someone asked that question about MFA controls ;)
| DubNorthEast |
Offline fused
« Reply #2 on: 30 January 2008, 18:45 »
The MFA shows the time when you turn the ignition on. If yours doesn't show anything then check the fuse, if the fuse is fine, check all the fuses since you might be checking the wrong one.....  :rolleyes: if all fuses are good then you probably have a broken/faulty MFA. I fixed mine by removing said fuse for a day then put it back in but the only other way I know is to buy second hand unit  :sick:
With the ignition on use a pin or other small poking devise to advance the time with the two buttons next to the clock.
The rear wiper is controlled on the same stalk as the MFA, it's on the front and slides to the right. If that doesn't work, there should be relays to check, not sure which though.
good luck
Offline gavL
« Reply #3 on: 30 January 2008, 18:48 »
What about reseting the MPG, as it seems to just vary....
| DubNorthEast |
Offline Conker
« Reply #4 on: 30 January 2008, 18:54 »
The pins for my MFA clock don't work anymore either  -  I have to wait until midnight then pull the fuse so that it resets to 00:00
« Reply #5 on: 30 January 2008, 19:03 »
Thanks guys,  :grin: hmmm yeah maybe the pins don't work then, there is a display, that seems to work, but i noticed when you slide the switch from 1 to 2 the display changes what does that mean and what are all the displays mean?  :undecided:
Currently Driving
Offline nikkyboy
« Reply #6 on: 30 January 2008, 21:04 »
Setting 1 on my 8v seems to show info recorded on a trip. It resets after leaving the car parked for an hour or so. Setting 2 shows cumulative info apart from oil temp or outside temp.  You can reset either sets of info by holding the slide switch past either 1 or 2 (depending on what you want reset).
Although I probably look at them every day I can't remember exactly what each one says.   :embarassed:  I think its time, journey time, distance travelled, average speed, mpg, oil temp and outside air temp?
Offline ...joe
« Reply #7 on: 30 January 2008, 21:26 »
of course it will vary with the differing speeds/revs/type of driving etc
to reset either position push the slider the whole way until it resets.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline DubFan
« Reply #8 on: 31 January 2008, 04:50 »
The rear wiper operates when you push the wiper stalk towards the Dash. Push once briefly the rear wiper starts, push briefly again and it will stop. Push and hold for a few seconds and it'll squirt water on the rear window and wipe.
Offline gavL
« Reply #9 on: 31 January 2008, 10:52 »
Cheers tip top info :)
| DubNorthEast |
