Author Topic: abf on kjet  (Read 814 times)
VeeDubGTI16v
abf on kjet
« on: 29 January 2008, 20:21 »
on the abf block on the front of the block bottom roght corner is a sensor with a wire attached. anyone know what its for? im pretty sure it needs removing and plugging if i run the engine on kjet. can someone confirm?
Re: abf on kjet
« Reply #1 on: 08 February 2008, 10:39 »
its a crank possition sensor if its the one right at the very bottom close to the engine mount bracket/oil filter housing.  You dont need it if running it on k-jet :)
Offline ben44
Re: abf on kjet
« Reply #2 on: 08 February 2008, 19:10 »
yeah its not used, just leave the sensor in the block and chop the wire off. (its a perfect bllanking plug would you believe! :wink:)
My signiture sucks..........................
VeeDubGTI16v
Re: abf on kjet
« Reply #3 on: 08 February 2008, 20:56 »
yeah that was the plan! cheers for confirming
