Author Topic: ECON button on - engine cuts out if heater blowers are switched on  (Read 1420 times)
Offline Mr Blue
The car is a mk4 1.8T with climate control.
If the heater blower is switched on (climate control) the engine cuts off!
Cant see anything missing in the engine bay.
Has anyone had this problem and how was it sorted?
chers
blue
Offline saul79
a/c compressor seized?
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline MaXXeH
  • Golf MK5 GTI
give it loads of revs and turn it on see what happens.
Offline Mr Blue
ac compressor - i was thinking the clutch on it (or something) maybe seized
Loads of revs and it still cuts out.
thanks for the replys
Offline Chris 'N' Jen
  • MK4 2.0 GTi 8v in black (the best colour)
Chances are if the ac compressor or related parts are seized as stated before the ECU will detect this and cut the engine before you have pieces of it flying around your engine bay as it destroys itsself.
All of the above is just a wild guess as i have no idea about ac systems.
take it to an ac specialist and see what they say.
 :smiley:
Offline ub7rm
To be clear on this does it cut out as soon as you switch the blower on - even in econ mode?  If its in econ mode the a/c compresser isn't energised so shouldn't be causing a problem.  If it stalls as soon as you take econ mode off then yeah I would blame the compressor too.
2020 BMW 128ti
2017 Golf GTD Estate
