Author Topic: tempremental water temp guage  (Read 794 times)
Offline shikta000
« on: 29 January 2008, 16:41 »
my temp gauge has started to act up and sometimes it decides to play and other times it refuses..i have changed the sender for a new one from gsf..same result...i'm assuming there must be a problem with the gauge itself, which would mean getting the dash out..uuuggghhh...before i do, any comments or similiar happenings?
Offline amgine
Re: tempremental water temp guage
« Reply #1 on: 30 January 2008, 02:19 »
i've seen it happen once before and heard of it many times. i believe u could have a dodgy earth on the back of the clocks, and yes i'm afraid u would have to take them out to investigate, but the whole dash doesn't have to come out.
To get the clocks out remove the steering wheel (its not neccessary but makes things easier), then all the switches, heater control knobs, stereo, plastic surround, and then u should be able to see the two screws that hold in the clocks. Once u have the screws out  u have to reach around the back of the clocks and disconnect the speedo cable..... after all that i think u should be able to lift the clocks out!! But its been a while so i might of missed out something.
Of course dont do any of that until ur sure the fault actually lies with clocks..... I'm sure some more people will post their opinions... eventually.
Anyways hope that hasn't depressed you... and good luck.
rub'a'dub dub
Offline shikta000
« Reply #2 on: 30 January 2008, 18:01 »
yeah cheers..i found an old post re; changing dash bulbs that my bro needs to do, and i logically thought that op would also help me ...any ideas on price of a gauge unit? if i need it
