Poll
which are better??
koni adjustables
eibach pro street
Author Topic: eibach vs koni  (Read 1700 times)
Offline joesgti
eibach vs koni
« on: 29 January 2008, 11:42 »
now i know that the eibachs are more expensive but what would the differences be? im ordering either the koni or eibach on thursday (payday :tongue:) and would like to know if there is much difference between the two? I know they are both adjustables so will go to the same height as each other but why are the eibachs more money??  :huh:
GTI MK5
Not the only GTI...........but the best! ; )
Offline RedRobin
Re: eibach vs koni
« Reply #1 on: 29 January 2008, 11:52 »
I don't know which are 'better' - What are the differences between them? A call to Awesome would yield some answers: 0161 776 0777 :smiley:
I have Eibach Pro-Kit springs and ARB's and Koni FSD shocks.
Offline gazbutmk5gti
Re: eibach vs koni
« Reply #2 on: 29 January 2008, 12:03 »
As RedRobin says call Awesome and talk to Dean, if you look at the 2 products in the flesh you can see the Eibachs are built to a much better standard in both finish and materials, there are also a few reports of the Koni's giving a bit harsher ride, but obviously not the FSD's
Revo stg2+ & lots more
Offline K1
Re: eibach vs koni
« Reply #3 on: 29 January 2008, 13:30 »
Dunno if this is valid. I have eibach dampers on the ed30 and Koni dampers(adjustable) on my previous rx-8. But i reckon the rx-8 had the better dampen characteristics especially going over speedbumps. Also, the Eibachs croak abit over speedbumps in winter for the first few miles. My rx-8 never did that. As a coincidence my eibach equipped astra way back then, croaked too over bumps.
If i did it again, i'd go fsd's or KW. Just my opinion though.
Kev
White Edition 30. Born 26th/June/2007. Highline, Xenons, IPOD+Armrest, Cruise Control. Dbilas intake, Forge short shift, GIAC fuel maps, Forge DV, Milltek Non-res Turbo back, Eibach pro damper, pro kit and anti roll bars. Black Monzas, Kenwood DNX5220BT, R32 Front n rear brakes
Offline RedRobin
Re: eibach vs koni
« Reply #4 on: 29 January 2008, 13:35 »
The FSD's are certainly very practical for road use and are very clever in their Smart ability to instantly respond and harden'soften accordingly. The only down side is that you are limited how much you can lower your car for the FSD's to function properly and safely.
Re: eibach vs koni
« Reply #5 on: 29 January 2008, 18:13 »
Kev
My Eibach anti-roll bars uded to creak until we used a different type of lubricant on the bushes.
The eibach coilovers are exactly the same as KW variant 1's, only cheaper, they even have 'made by KW' on them. Most shocks are made by the same companies then badged up to suit, think there are only 2 or 3 damper manufacturers , Sachs, KW and bilstein I think and they all manufacture under licence
Offline jonathonturner
Re: eibach vs koni
« Reply #6 on: 29 January 2008, 22:00 »
mines running eibach ( kw made)..had them on for 10000 miles..
there the bollocks mate..taut but comfortable.
i think this is the best set up by a mile.
