Author Topic: rear engine mounts cause bad vibrations  (Read 855 times)
Offline Mr Blue
« on: 29 January 2008, 11:06 »
hello
After changing my rear mounts ive got a bad vibration at idle. Real annoying!
Ive played with the idle speed and I still get a vibration till I rev the engine over 2k+.
Checked the the mounting bolts and they are all tight.
Could it be the front engine mount thats causing this vibration now?
Blue
Offline Diamond Hell
  • Opinions я Us
Re: rear engine mounts cause bad vibrations
« Reply #1 on: 29 January 2008, 11:18 »
Slacken off the mounting bolts, run the engine and see if it makes any difference.  only start the motor and blip the throttle a couple of times.
If you then carefully tighten them up it may well be that you'd somehow managed to do them up where they weren't sat right and slackening off the bolts will allow the engine to come back to where it's happy.
Failing that, put the old mounts in and see if the vibration goes.  It may just be that replacing those worn components has highlighted other tired items that are now complaining cos they're operating differently to what they have for the past 5-10 years.
Offline Mr Blue
« Reply #2 on: 29 January 2008, 11:25 »
Ill give that a go. thanks :smiley:
