Author Topic: carbs  (Read 1424 times)
Offline mwep201081
carbs
« on: 28 March 2004, 23:39 »
is it possible to fit twin webber 40s onto a 1.3 mk 2?
VeeDubGTI16v
Re:carbs
« Reply #1 on: 29 March 2004, 10:37 »
why would you want to do that?
Offline 90 red 8v
Re:carbs
« Reply #2 on: 29 March 2004, 18:10 »
Now Now, play nicely  ;). Yes you can fit twin 40's to a 1300, there was a white Mk2 featured in Performance VW (fully stipped out, caged, rally front end....). Bear in mind that the insurance compaies will love you for fitting thema and you may have to get a custom manifold built (I don't know if an 8 valve 1800 inlet will fit). Plus you'll need an uprated fuel pump and unless you have had a load of work done on the head and a fairly racey cam fitted you'll be over fueling. If it is a faily standard engine, go for a webber replacement carb as not only will the choke work, you'll get a small increase in power and most insurance companies wont put up your premium.
Hope this helps,
Craig
