Author Topic: mk2 16v problems  (Read 1649 times)
Offline golfmk1
mk2 16v problems
« on: 28 January 2008, 13:30 »
i have just bought a mk2 golf gti 16v 1.8 kr 1989
it has no bottom end power atall unless i boot it it wont go anywhere! it is using alot of fuel!
i was wondering if anyone could help me? i have been told it might be due to lack of air getting to the engine in which case i have 2.0l induction parts!
cheers Edd
Offline Uruk Hai
Re: mk2 16v problems
« Reply #1 on: 28 January 2008, 13:39 »
Could be a few things, try the search function, there's loads about 16V's on here
Offline Conker
« Reply #2 on: 28 January 2008, 15:13 »
I'd try a full service first to see if that helps: Oil/filter/plugs/rotor arm/fuel filter/air filter, plus new spark plug leads if they look knackered.
Then you could look at engine timing.
If it still feels pants you could have it rolling roaded for around £30 to proove its power, or for about £80 you can have a rolling road tune-up.
Offline golfmk1
« Reply #3 on: 29 January 2008, 09:09 »
think im going to put my 9a 2.0l in it its pouring cream into the airbox from the block breather! but no  oil in water and no water in oil  :angry: i have checked timing, oil is new and filter leads look mint as does the rotor arm etc,  :angry:
Offline Conker
« Reply #4 on: 29 January 2008, 10:30 »
Do you mean the crankcase breather?  If so, that pipe can get full of mayo, but its quite normal, especially if its not been on many long runs. I guess moisture can get down the pipe from the airbox and react with the oil traces in the pipe.
Offline golfmk1
« Reply #5 on: 29 January 2008, 10:49 »
hmmn :sad:
Offline golfmk1
« Reply #6 on: 30 January 2008, 13:43 »
FOUND THE PROBLEM  :grin: CO2 SCREW ON THROTTLE BODY WAS NEARLY FALLING OUT SCREWED IT IN A BIT AN SHE GOES LIKE A GOOD UN  :grin: GONNA GET IT SETUP PROPERLY TONIGHT  :grin:
THANKS FOR ALL YOUR SUGGESTIONS  :grin:
Offline Conker
« Reply #7 on: 30 January 2008, 16:15 »
The screw on the throttle body is the idle screw. The CO2 screw is on the metering head. If your idle screw was falling out, surely you would have had huge idle problems (hunting, or a 2000rpm idle speed)??
Offline golfmk1
« Reply #8 on: 31 January 2008, 08:59 »
ok it was fine when it was hot lol must have altered the mixture somewhat to make it run better? it doesnt start when cold now lol it didnt hunt when it was warm though stupid car
Offline golfmk1
« Reply #9 on: 07 March 2008, 17:04 »
2.0l engine in and rolling roaded @158bhp just over 150ft lb torque, still havent put kr cam in though well happy with the power  :smiley:
