Author Topic: accelerating noise turbo??  (Read 8252 times)
Offline Starry
  • http://planetweed.co.uk
Re:accelerating noise turbo??
« Reply #10 on: 31 March 2004, 18:33 »
if your still getting a strange niose after changing the dv it may just be your wastgate chattering which is not a prob..
1.8T 200bhp/237lbft.r32 F/BUMPER/ MILLTEK TURBO BACK,WITH HI-FLOW CAT/REVO/BAILY DV30/FRONT MOUNT I/C
Offline papperbear
  • Ding Dang Doo ...!
« Reply #11 on: 02 April 2004, 11:27 »
Thanks for all the advice .. even went to the trouble of asking my insurance company whether it would be ok to install an alloy dv and they said as long as it doesnt increase performance then yes.
The offical line from Forge Motorsports was that it should produce a smoother gear change by stopping turbo lag.
So purchased FMCL007P Fast Road Closed Loop Diverter Valve (piston) from Forge Motorsports.  Should arrive Monday - show pics after its been done.
Gazza - let me know how ur gettin' on?
Offline gazzagtiT
  • Houston, we hav a pic here!!
« Reply #12 on: 02 April 2004, 12:58 »
yeah cheers fella's i thight starry might have the answer cheers fella,
pappa, how much was yours?
the one u bought is that one in the link i put on here or dif?
Its all better now very shiny, but now the windows have gone again! and shocks are squeaking like mice!!aarrgghhh
Offline DaveG
« Reply #13 on: 02 April 2004, 14:02 »
The unofficial line being that (unless you're talking high boost applications) dump valves are a waste of time other then for accoustic pleasure.  VW's will surely have a recirc valve or silent dump to atmos???!!
Also- wastegate chatter IS a problem, you'll be leaking boost each time it chatters i.e. it's not sealing so it's venting boost on each open/close cycle.  Probably marginal - but all the same, losing boost.
Offline Rally_Chris
« Reply #14 on: 02 April 2004, 15:08 »
Quote
Dave - although people have incorrectly referred to it as a dump valve, the Forge item is a recirculating 'diverter valve' that replaces the standard VAG/Bosch 'boost valve'. It is not a vent to atmosphere device - leave those to barry boys in RS turbos!!
http://www.golfmk4.co.uk
Mk4 Cruise Control Installation Expert
Offline papperbear
« Reply #15 on: 02 April 2004, 15:54 »
Gazza - I bought one from Forge Motorsports for ?80.  I read a couple of reviews and its seems to fit the bill and not that difficult to install.
Offline gazzagtiT
« Reply #16 on: 03 April 2004, 20:49 »
let me know how it goes mate, an ill wait for pay day an get mine!!
Offline gazzagtiT
« Reply #17 on: 04 April 2004, 00:05 »
http://www.forgemotorsport.co.uk/vw18t.asp?cat=vw18t&catalog=vw18t
Whats the difference between the 006 and 007 i no it says "piston" but how does it effect the car? anyone? ???
Well getting into this turbo stuff now its so easy to fit aswell!! ;D ;D :P
Offline antgti
  • 130PD Gti with Van aaken chip to 165 has now gone,
« Reply #18 on: 04 April 2004, 03:21 »
The reason why piston ones came about was because they are more reiable, and some cars cannot run witht the Diaphragm stylke ones.
I remember on my old Punto GT turbo, you had to use the Piston dump valve as the Diaphragm type would allow air past and would mean the car would'nt idle. This was cured by the piston D valve.
Me old diesel was quick/........
16.004 sec Qtr mile @ 85mph 23/5/04 Santa Pod
Now running around in soon to be REVO'd Seat ibiza 1.8T 20v FR and missing the fuel economy..............
Offline papperbear
« Reply #19 on: 13 April 2004, 08:21 »
Now fitted my DV.  Left pics at home along with my body this morning!
Its funny ... from what you read on instructions it should be easy.  Things that I found weren't quite like the instructions ...
  • The clips on the hose's were all fixed in (no screws to undo them)
  • The small vacuum pipe was smaller than the nozzle it had to go on, so a little improvisation was in order (see pics)
The rattley noise seems to have gone, so it looks like it cured the problem.
« Last Edit: 13 April 2004, 08:23 by papperbear »
