Author Topic: Painting your disk brakes (to look like MK3 Anniversary Edition)  (Read 2066 times)
Offline eightyeightmph
Just thought I'd give it a go....
First I picked up a can of Halfords finest brake caliper (HT) paint. In red of course as I'm giving my valver that Anniversary look.
Pop the car up on stands ( I did one side at a time ) & drop the wheels.
Grab yourself a nice big wire brush or an attachment for your drill & have at it with the brakes.
NOTE: You will sneeze/cough/spit black if you don't wear a face mask!
I happened to have some painters masking tape lying about but any will do. Mask off everything that you don't want to paint, valves, pipes & disks being the obvious.
It says on the can that the paint is 'touch dry' in 15-20mins. As it was flippin' cold I had to double that & at one stage resorted to placing a heater near the brakes.
Anyway, as I had done a blinding job cleaning up the calipers but had no primer I'd put a thinish first coat on.
Please excuse my naff camera phone pics. I can assures you the paint is bright red not barbie pink!
Once this was dry (both front & rear) I put the second coat on.
It started too look pretty good, after it had dried I was happy with the finish & voila.
With my filthy wheels back on I think it gave the car the 'right' look!
Thank you for your time! :wink:
88's VW Emporium!
2016 GOLF GTD
Offline Mikester
  • Civic Type R
BUMP
 :cool:
Offline Pete Taylor
Good trick is to use a hairdryer or heat gun on it inbetween coats. Tried that doing my last wheel and did it in half the time
Used an electric radiator! :wink:
2016 GOLF GTD
Offline LazyLunatic
  • MK3 20VT Project
How much was the paint and how much of it did you use?
Was looking at doing this too!
LL ;)
